Discussion topic: My sky Q Box is working and audio is working but there is no picture. The screen is black
Message posted on 23 Oct 2023 07:29 PM
The sky Q box is working and audio is working but the TV screen is blacked out.
Message posted on 23 Oct 2023 07:34 PM
Re: My sky Q Box is working and audio is working but there is no picture. The screen is black
Hi @S28
Message posted on 23 Oct 2023 07:37 PM
There is no menu the TV has blacked out
Message posted on 23 Oct 2023 07:41 PM
Yes, my error @S28
Should have realised that you cannot access any menus.
Have you tried rebooting the Q box.
