Discussion topic: My satellite sky Q box wont reset its self
This message was authored by: Slowson72
Any one have any ideas on hiw to get it working
Re: My satellite sky Q box wont reset its self
Hi @Slowson72
Have you tried a simple reboot.
If you had to press the Standby button on the Q box to start it try completly resetting your Bluetooth remote.
