Discussion topic: My remote has stopped working I’ve put 3 sets of new batteries and nothing it’s been working
Message posted on 28 Feb 2024 06:49 PM
I have been using my sky all day and attempted to change channel and the remote won't work
ive switched sky off and back on again but my remote just isn't sending a signal I have changed the batteries 3 times but nothing
can anyone help me? My sky box is on standby now and I can't even switch it on
Message posted on 28 Feb 2024 06:58 PM
Re: My remote has stopped working I’ve put 3 sets of new batteries and nothing it’s been working
@Amanda270570
After checking the basics, ie; re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well as the above you’ll have a spare.
Message posted on 28 Feb 2024 07:24 PM
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 28 Feb 2024 07:49 PM
I have switched the box on now but the remote is as dead as a do do
ive tried to press 7 and 9 but it doesn't light up at all it's as if it's died 🤣🤣
Message posted on 28 Feb 2024 07:52 PM
Thanks everyone I am going to buy a new remote and have ordered one from sky
Message posted on 28 Feb 2024 07:53 PM - last edited: 28 Feb 2024 07:57 PM
Was that Pressing and Holding 7 & 9 together.
You need to hold them for a few seconds.
Also does the LED on the remote light when you press the Question mark (?) button or the Microphone button on the remote. These are the only individual buttons that will illuminate the remote led.
