6
This discussion topic has been answered Discussion topic: My recordings on sky q arent showing and its saying currently unavailable
This message was authored by: Lyne1
Go into my recordings and it's saying currently unavailable
Re: My recordings on sky q arent showing and its saying currently unavailable
@Lyne1
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
@Lyne1
Hi @Lyne1
If you also cannot make new recordings check through the following link.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Avatar for Lyne1
Thank you I've got it working finally had to rest my box a couple of times
Keep an eye out for hard drive errors. Might be on its way out.
This message was authored by: dilydol
Having to reboot the system every time we try to watch recordings. Been going on for a couple of weeks now!
do think the hard drives on it's way out?
Almost certainly
