10
This discussion topic has been answered Discussion topic: My recordings are no longer accesable and it requests a increase in my subscription?
This message was authored by: 1Tolcarne
When trying to access my recordings it does not allow this and simply requests a increase in subscription. Needless to say losing the will to live to get any sense or speak to a human being. Considering cancelling the whole package after 20yrs
This message was authored by: nigea99 Answer
Re: My recordings are no longer accesable and it requests a increase in my subscription?
hi @1Tolcarne
I am guessing the message is not on a recording from Live TV but something you have downloaded from Catch up/On demand
Typically customers get this message when they try to download something is in HD without having the HD subscription
In this case as the default download quality is set to HD (high Definition) not SD then when you try to download and watch you are prompted to upgrade (i.e. take out the HD subscription)
You, probably, just need to change your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
(Please note this setting can only be set on the Main box)
@1Tolcarne
Have you mistakenly tried to record in HD without the HD add-on?
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Avatar for 1Tolcarne
Level 0 icon
I do not want a XXXXXX badge I want an answer and to speak to someone
hi @1Tolcarne
@1Tolcarne
I have already replied. This is a customer helps customer forum and you aren’t contacting Sky Customer Services on here.
Level 0 icon
Its precorded series of tele shows and programs collected over the year. Favourites recorded to view again. Not over capacity,
Have you made any changes to your subscription (especially removing the HD add on) ?
Please may we ask which channel is it from ?
Level 0 icon
Hi upgraded my subscription over a month ago. Its simply favourite TV series such as Mortimer and Whitehouse, Still Game etc stored in recordings section. I have tried the advice to change the setting to SD but still the same message to upgrade my subscription and no access to saved recordings
I have escalated your post to a SKY support team, who, hopefully, will be in touch.
Please see this link re the escalation and what you might see:
If you are using Safari I believe you must make sure that 'Hide IP address' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
This message was authored by: Greenfingers001
Thanks for escalating this. We’ve sent @1Tolcarne  an invite to chat.
This message was authored by: Lisa-P1987
We are still looking to help you 1Tolcarne . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Answered - Go to Answer
