Discussion topic: My recordings and stations not showing
This message was authored by: Yemi
Hello, I got this message when I want to view my recordings and station. 'Please ensure the correct viewing card is inserted with chip facing up
Re: My recordings and stations not showing
Hi @Yemi
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
This message was authored by: Re22
Programs, recordings and apps still not showing
Hi @Re22
Why have you changed your Account from
@Yemi
Avatar for Yemi
I followed the process. I went to settings to setup the my viewing card. It is still not working. Is there a number I can call to resolve this issue
