Discussion topic: My puck picture and sound sky Q will only work for a v short while then blue screen and error messag
Message posted on 18 May 2025 03:06 PM
I am new to Sky Q and use Sky streaming via EE broadband that is fast and Apple TV works fine
However if you choose ANY channel it works then buffers and then picture and sound goes and sign saying programme loading and then blue blank screen
is the puck faulty???
Message posted on 18 May 2025 03:10 PM
Re: My puck picture and sound sky Q will only work for a v short while then blue screen and error me
Hi @Picassorichard As Sky Q does not have pucks, your post is very confusing. Do you mean a Sky Q Mini box?
Message posted on 18 May 2025 03:12 PM
@Picassorichard Your post is a bit confusing as you mention both sky Q and sky streaming, you can't run both off the same account registered to your address as they are different sky tv products and sky only allows the use of one or the other at a registered address
so can you confirm which product you have Q or stream
