Discussion topic: My new sky mini box has arrived it won’t connect giving error code MR001
This message was authored by: MartinaMBostock
Ordered new mini box for upstairs but it won't connect. We have the main box downstairs and another mini but it won't connect to either. We also have a booster box in the kitchen to improve our WiFi 🛜
Re: My new sky mini box has arrived it won’t connect giving error code MR001
Hi @MartinaMBostock
Assume it is a Sky Q WiFi booster. Q boxes will not connect to if it is not.
First try rebooting the main Q box and then when this is completely back up and running reboot the problem mini.
Reboot the mini as above.
If you are on Sky Broadband and the Router or. Sky Q booster is nearer to the mini than the main box then you can try pressing WPS on that  instead of the main Q box. If you do this on the router make sure you press the Sky router WPS button and not the router reset button.
