2
This discussion topic has been answered Discussion topic: My new Sky Q viewing card is stuck in the box. How do I get it out?
This message was authored by: Tjackson1210
I put a new Sky Q viewing Card in the Sky Box but I think it might be upside down. I pushed it in but it won't come out. It won't push in to pop out and I cannot pull it out. Any ideas?
This message was authored by: twilight+princess Answer
Re: My new Sky Q viewing card is stuck in the box. How do I get it out?
Could you try tweezers or thin nosed pliers to grab any part of the card which is showing?
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
Hi @Tjackson1210
It will not pop out enough to remove it then you will probably need an engineer.
Virginia.
