Discussion topic: My new Sky Q mini box won’t connect to the main box and I can’t get to speak to Sky Support
This message was authored by: Tom1973
Just got a new Sky Q mini box but it won't connect to the main box, said to be a broadband issue and said to need an IP address. Can't get to speak with anybody from Sky which is not helpful.
any ideas?
Re: My new Sky Q mini box won’t connect to the main box and I can’t get to speak to Sky Support
any ideas?
May I suggest you restart both  your Router & Main box
The first thing is to restart your Router
Then when it is back restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted try connecting your new Mini box again.
any ideas?
Hi @Tom1973
Assume you are Carrying out a Network reset on the mini.
This message was authored by: JohnLeda
Thanks its been driving me mad this issue.
JL
This message was authored by: Zeezee48
Worked for me!
