This discussion topic has been answered Discussion topic: My multi sky box will not connect to the internet.
Message posted on 05 Jun 2024 11:57 AM
My sky multi box will not connect to the internet
Message posted on 05 Jun 2024 12:30 PM
Hi @Dublin22
Unless you are on Sky Broadband the mini connects through the main Q box and not your WiFi.
Either way try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Hi @Dublin22
