Discussion topic: My multi screen in my bedroom is not working it says it has no signal, my main telly is working ok
Message posted on 17 Jul 2023 04:38 PM
My main telly is working fine with a signal so I don't understand why my multi screen in my bedroom isn't.
Message posted on 17 Jul 2023 04:46 PM
							Re: My multi screen in my bedroom is not working it says it has no signal, my main telly is working
@English+B Is it no signal or No saellite signal? The 2 are different things.
Message posted on 17 Jul 2023 05:38 PM
Hi @English+B
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
