Discussion topic: My multi room sky box is showing Error MR001
This message was authored by: ELAINE1106
Re: My multi room sky box is showing Error MR001
@ELAINE1106
First thing to try is a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
