Discussion topic: My multi room sky Q box in bedroom is always glitching so frustrating
Message posted on 29 May 2024 10:40 AM
My multi room sky Q box in bedroom is always glitching so frustrating. We tried switching off and also rebooting conecting to our Sky router
Message posted on 29 May 2024 10:45 AM
Re: My multi room sky Q box in bedroom is always glitching so frustrating
Hi @Aftab4060
Reboot the mini as above.
