Discussion topic: My multi room boxes keep glitching plus can take up to 10 seconds to change channels and one box kee
This message was authored by Tony4790 This message was authored by: Tony4790
Am I entitled to replacement multi room boxes as present ones aren't fit for purpose
Re: My multi room boxes keep glitching plus can take up to 10 seconds to change channels and one box
Hi @Tony4790
Edit
I have deleted your other post as there is no need to make multiple threads with the same issue.
Suspect you will need an Engineer from Sky to check your system.
You can try the following:-
Reboot the mini as above.  Start with the mini nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box.
