Discussion topic: My mini sky box is not showing tv guide
Message posted on 24 Sep 2023 09:15 AM
Re: My mini sky box is not showing tv guide
Sky do not care. They just want to grab our money.
Message posted on 19 Oct 2023 09:03 PM
I've got this problem, been like it for ages it's really annoying
Message posted on 19 Oct 2023 10:31 PM
I've had this issue for a year now. I'm currently rebooting my main box two or three tiles a week. The box reboot solution is just temporary. There doesn't seem to be a permanent solution to this issue and because it only seems to affect a few customers and not all of them, Sky aren't interested in investigating the cause.
Message posted on 04 Dec 2023 10:14 PM
@sandihall I've had this problem for over a week but tonight the guide came back
I rebooted the mini box (as I have done about 3 times a day) but tonight it failed to connect to my Q box (previously it had shown as connected). A message came up saying it couldn't connect and asked me to try again later or press ? for help.
I pressed ? and and it suggested I reactivate by going to Settings, Status, Reactivate. I did this and the box rebooted, but this time the TV guide returned.
I wish I could explain it, It may be down to the sequence of events or just luck but it may help you.
Message posted on 30 Dec 2023 02:46 PM
The TV guide is not showing
Message posted on 15 Feb 2024 10:39 PM
Same here main box ok all mini boxes show half of listings so disnt always record going on for weeks now. Rebooted many times. Sometimes says on mini box viewing card not paired. But main box says paired
Message posted on 15 Feb 2024 10:43 PM
@Chris+jewity when you say you have rebooted many times have you also rebooted the main box first before the mini boxes
Message posted on 15 Feb 2024 11:25 PM
Yes main box first. Main box is ok just mini boxes missing lots of listings so you can't see what's on or record
Message posted on 19 Dec 2024 08:41 PM
I have had this issue, a Sky engineer came out. He said he never seen this before.
He changed the mini and did some things. Called sky also.
It fixed as it would do if you keep resetting it. but 2 days later its gone again.
I think it could be a main box issue if thats where the data comes from.
Message posted on 19 Dec 2024 08:44 PM
So it's unclear whether you've rebooted both boxes.
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with all mini boxes -
~ press the 🏠 button
Message posted on 19 Dec 2024 08:48 PM
This issue has been going on for the last year.
I have rebooted the internet
Hard reset all boxes
rebooted main box.
rebooted mini boxes
then i hard wired ethernet the boxes.
Any 1 of the sky q mini boxes will lose the tv guide, recordings and apps. It will just be loading.
