Discussion topic: My mini box won't work. It's saying no signal
This message was authored by: Pantiles
My mini box is not working. It's saying no signal
Avatar for Pantiles
Level 0 icon
Re: My mini box won't work. It's saying no signal
My mini box isn't working. It's saying no signal
Hi @Pantiles
Reboot the mini as above.
