Discussion topic: My mini box won’t connect to my internet
This message was authored by Ajames475 This message was authored by: Ajames475
My mini box won't connect to the internet but the network works on every other device. It connects to the main box though.
Re: My mini box won’t connect to my internet
Hi @Ajames475
Reboot the mini as above.
