Discussion topic: My mini box is not connecting to Q box
Message posted on 13 Jul 2024 09:13 PM
Mini box not connecting to Q box
Message posted on 13 Jul 2024 09:47 PM
Re: My mini box is not connecting to Q box
Hi @Naviwala
Reboot the mini as above.
Message posted on 14 Jul 2024 07:26 AM
Screen on second mini box keeps saying to reboot router and to ensure all sky q products are on. We have done this a number of times in the last few days and nothing happens
