Discussion topic: My mini box has stopped working technical fault messages when there is nothing wrong if you reset
Message posted on 24 Jun 2023 10:28 AM
Mini box stopped working tech faults with everything. Reset works sometimes now that has stopped
Message posted on 24 Jun 2023 10:39 AM
Re: My mini box has stopped working technical fault messages when there is nothing wrong if you rese
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
