Discussion topic: My mainbox says no subscription on multi room but I am paying on account. It won't work
This message was authored by Steve1231 This message was authored by: Steve1231
On main box says I've not got multi room subscription, this all broke after re taking offer after I cancelled 9th June. My broadband has also changed so I waited until that in case that may of been problem but doesn't work after connecting mini box. The team said give it 3 days this was 2 weeks ago and no one bothered to call me back. How do I get this working??
Re: My mainbox says no subscription on multi room but I am paying on account. It won't work
Mmm. 9th June was only 5 days ago @Steve1231
However try the following.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Failig this try rebooting the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Failing all of the above best to get back to Sky.
This message was authored by LynnL79 This message was authored by: LynnL79
We are having exactly the same issue after taking a new deal. Did you get yours sorted??
This message was authored by Wright79 This message was authored by: Wright79
Any resolutions? Exactly the same for me? Got engineer coming tomorrow? Feels like an account issue rather then hardware?
It's been a long process to finally get ours sorted!
The engineer will not be able to fix it. They will call a centre and ask them to send yet another signal down the line and tell you to wait 3-5 days. This will also not work.
i argued and pushed for a new viewing card. They eventually agreed and sent us one..but...they completely deactivated our current viewing card so lost everything for 3 days whilst waiting for the new viewing card.
once the new one arrived it didn't work at first so yet another call to sky to get them to send another signal down the line... this worked and so far so good! Just to phone and now get a refund for all the services we paid for but didn't get for nearly 3 weeks! Good luck!
Thank you - so frustrating isn't it! Sky said its has nothing to do with my contract renewal ! Just coincidence!  But all happened on the same day!
