Discussion topic: My main sky mini box says problem with satellite signal
This message was authored by Joanne123123 This message was authored by: Joanne123123
I can't get programmes on my sky mini but connected to internet. Says issue with sky signal??
Re: My main sky mini box says problem with satellite signal
Hi @Joanne123123
Reboot the mini as above.
