Discussion topic: My main sky Q box has started to make buzzing sound.
This message was authored by: Ryan12100
My Sky Q box has started to make a constant buzzing sound. It has become very loud and is over the sound of the TV. I have turned of the box for 2 minutes on multiple occasions but the sound is still there. All features of the box are still working fine but the nose has become very annoying.
This message was authored by: s48z
Re: My main sky Q box has started to make buzzing sound.
If you've reset it and it's still causing problems (assuming the box is in a good position with nothing causing it to heat up - radiators/box being covered/etc), you may need to replace the box.
Not sure which box you have but found these which will hopefully help.
Sky Q: https://www.sky.com/help/articles/sky-q-boxes-are-warm-to-touch-or-noisy
Sky+HD: https://www.sky.com/help/articles/sky-box-is-noisy
Hi @Ryan12100
This message was authored by: Hjj20
My Sky Q box is making loud buzzing sounds, recording function not working
I have to keep resetting my sky Q box but the buzzing sound is getting worse.
This message was authored by: Jadeee
Re: My Sky Q box is making loud buzzing sounds, recording function not working
Hi,
If you need to keep resetting your box and have reset the harddrive and the issue is getting worse you may need to look at getting the box replaced. These links can help with that depending on the type of box you have it can normally be replaced online:
Avatar for Ryan12100
Thank you, I have tried this but the sound is still there.
