Discussion topic: My main box seems to be working fine but no shank on my mini box
This message was authored by: SAW121J
I have signal on my main box but my other mini boxes all say no signal?
Re: My main box seems to be working fine but no shank on my mini box
Hi @SAW121J
Reboot the minis as above. Start with the one nearest to the main Q box.
If the mini still do not connect try a Network Reset on the minis.  Again start with one nearest to the main Q.
You will be asked to press the WPS button on the main Q box (not the mini).
You can use the WPS on another mini if already connected and it is nearer than the main Q box.
If you are on Sky Broadband and the Router is nearer to the mini than the main box or another connected mini, then you can try pressing WPS on the router instead of the main Q box.
