Discussion topic: My main SkyQ box is showing a snowy screen
This message was authored by: Becki5
The normal menu screen shows for a second then goes snowy/fuzzy
Re: My main SkyQ box is showing a snowy screen
First thing to try if you haven't already is a reboot @Becki5
Avatar for Becki5
Level 0 icon
Yes, did try rebooting. Trying it again now. Thank you 😊
Avatar for Becki5
Level 0 icon
Thank you! Worked the second time! 😀
