This discussion topic has been answered Discussion topic: My home network is not working, Wi-Fi is ok but only when I am next to the router
Message posted on 09 May 2024 12:38 PM
My wi-fi to the house works ok, but I can only use my laptop in the room the router is in & my Sky Q box keeps dropping out so I cannot download on the tv.
Message posted on 09 May 2024 12:49 PM - last edited: 09 May 2024 12:50 PM
Hi @BCW1
For any issues with your WiFi if you are on Sky Broadband then you need to post in the Sky Broadband forum.
Regarding your Q box connection to your router try the following.
Hi @BCW1
