Discussion topic: My channels 4 and 5 have disappeared
This message was authored by: JovisMum
About 10 days ago Channel 4 and 5 stopped working on my Sky Q - saying the channel was affected by a signal issue.
I can manually tune them and watch them that way but that doesn't fix the issue via the TV Guide - I've done a software update and all my cables are working .
help!
Re: My channels 4 and 5 have disappeared
help!
Hi @JovisMum
Avatar for JovisMum
Thanks so much - sadly it didn't work 🥲
