Discussion topic: My channels 4 and 5 have disappeared
Message posted on 26 Sep 2023 08:19 PM
About 10 days ago Channel 4 and 5 stopped working on my Sky Q - saying the channel was affected by a signal issue.
I can manually tune them and watch them that way but that doesn't fix the issue via the TV Guide - I've done a software update and all my cables are working .
help!
Message posted on 26 Sep 2023 08:27 PM
Re: My channels 4 and 5 have disappeared
help!
Hi @JovisMum
Message posted on 26 Sep 2023 10:46 PM
Thanks so much - sadly it didn't work 🥲
