Discussion topic: My broadband want connect to my qbox
This message was authored by: Kasim
Sky box
Re: My broadband want connect to my qbox
@Kasim wrote:
Sky box
Hi @Kasim
If on Sky broadband first reset your broadband router by holding Reset on the back until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
