Discussion topic: My booster sky internet only shows 2 green lights and my Q box won’t recognise the signal from my rt
This message was authored by Charlie+Mth This message was authored by: Charlie+Mth
Charlie+Mth
Re: My booster sky internet only shows 2 green lights and my Q box won’t recognise the signal from m
My sky Q is not recognising my router and the booster only shows 2 green lights
Hi @Charlie+Mth
If you are trying to connect your Sky QWiFi  booster to your router then
  1. With the power and wireless lights on green.
  2. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your hub for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  3. After a few minutes, the connected light will turn green. You're all set up.
Then to connect your Q box carry a Network Reset found in Q box Home - Settings - Setup - Network.
If you are on Sky Broadband you will be asked to press the WPS button on the nearest Sky Q device (Not on the Q box as the Network reset will start the main Q box WPS automatically). You can use the WPS button on on the Booster if it nearer to the main Q box then the the router.
If the the router is nearer to the main Q box then make sure you press the WPS button on the Sky router and not the reset button.
