16 Oct 2024 07:51 PM
I've turned my box on after paying the bill, and the hd apps and all the apps like Netflix and YouTube aren't there anymore
16 Oct 2024 08:02 PM
You can check here, how to access the hidden menu. After that, you simply have to go to Apps and select refresh apps. After that, all apps should be visible.
16 Oct 2024 08:04 PM
Posted by a Superuser, not a Sky employee. Find out moreThat doesn't always work and it's just a matter of time for the box to sort itself out.
16 Oct 2024 08:06 PM
It works 99% of the time. It can take up to 4 hours for all apps to appear. He can try resetting settings, but after that will need to do the setup for the remote as well.
16 Oct 2024 08:17 PM
I tried the refresh apps and nothing works
16 Oct 2024 08:21 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Gem1978 How long had the box been turned off?
16 Oct 2024 08:25 PM
10 minutss
16 Oct 2024 10:27 PM
Posted by a Superuser, not a Sky employee. Find out moreLeave it on standby and check tomorrow.
