Discussion topic: My TV says it does not have internet connection, I have tried rebooting and reconnecting is settingb
Message posted on 07 Jul 2024 04:26 PM
I cannot access any apps on sky, a message pops up saying it looks like you do not have internet access, I have tried rebooting it and setting it up again in settings but nothing works
Message posted on 07 Jul 2024 04:38 PM
							Re: My TV says it does not have internet connection, I have tried rebooting and reconnecting is sett
Hi @Andy887
Message posted on 08 Jul 2024 11:39 AM
Good morning
Thanks for getting back to me, I think I saw your similar advice to another customer before I posted my problem and tried all your advice, sadly none of it worked and so actually got hold of a human at Sky, explained all the above and am now waiting on an engineer to rock up, thanks again all the same for your time, appreciate it.👍
