Discussion topic: My TV keeps saying no signal can’t get sky at all
Message posted on 25 Apr 2024 11:31 AM
My TV Keith saying no signal can't seem to get sky at all
Message posted on 25 Apr 2024 11:33 AM
Re: My TV keeps saying no signal can’t get sky at all
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
Message posted on 25 Apr 2024 11:56 AM
@brenda+gregson wrote:My TV Keith saying no signal can't seem to get sky at all
Not helpful, but I love the fact that you call your TV "Keith" 😂
