02 Mar 2024 03:02 PM
Sony TV randomly turns off and on when using sky q. Doesn't happen if using fire stick or casting. Very frustrating...any ideas from Sony TV owners?
02 Mar 2024 05:03 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @sj150 Unless you have a loose lead the Sky Q box does not have a CEC command to turn off any TV. Turn on a TV yes, turn off no.
02 Mar 2024 08:47 PM
Hi @MightyQuinn , all connections are secure. I can be watching anything and TV just goes blank then after few seconds picture comes back. Never happens if I cast or use firestick... hence I think sky q box problem? Have a mini box in another room with another Sony TV which is grand 🙄
02 Mar 2024 08:51 PM
Posted by a Superuser, not a Sky employee. Find out more02 Mar 2024 09:26 PM
Hi@oldfella, that sounds like something worth trying... I'll give that a go tomorrow and let you know if it's worked 👍
03 Mar 2024 08:03 PM
Hi @oldfella ,
Tried what you suggested...moved mini box to TV, put main q box in standby and used mini box.
It worked perfectly, no TV going off and on!
I'm assuming it's a problem with main sky q box?
Thanks for suggestion👍
03 Mar 2024 08:15 PM
@sj150 wrote:
Hi @oldfella ,
Hi @sj150
Make sure that the Standby mode is the same in all the Q boxes
If you haven't already try a Reset Settings in the main Q box hidden menu.
