Discussion topic: My Skybox loses network connection randomly and I need to input the router password to connect
This message was authored by: rhea247
For some reason my Sky box is losing connection with my router. I go to Settings and the message shows connection is lost.
Pressing reset doesn't work. I need to enter all details again. There's no pattern to the loss in connection. It can happen midway through watching a programme, or after several hours connected.  It means I cannot connect to the Apps which is mostly what I use my Skybox for.
I changed broadband provider and have a new router. This was approx 3 months ago. The drop in connection started mid December, so the new router was working perfectly fine at the beginning.
Any advice from the kind community?
This message was authored by: Mr+Flibbles+86
Re: My Skybox loses network connection randomly and I need to input the router password to connect
Hi there @rhea247, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
