6
This discussion topic has been answered Discussion topic: My SkyQ box has a message Hard drive not working. I have completed a hard drive reset, but no joy.
This message was authored by: JSky73
Do I need to request a new SkyQ box as this one is quite old now?
This message was authored by: lettice Answer
Re: My SkyQ box has a message Hard drive not working. I have completed a hard drive reset, but no jo
Looks like you have done the reset and that has not cured your fault.
Have a read of this Sky help article, about hard disk problems and at the bottom you can order a replacement box for delivery to your home, swapping out the old one.
You need to be logged into your sky account after clicking that link.
Sky Q Hard Drive error messages | Sky Help | Sky.com
Avatar for JSky73
Thanks for this.  The normal reset did not work, but the factory reset did work.  The box is quite old now, so it may need replacing soon.  Appreciate the reply.
This message was authored by: Daisy58
I have no done a hard drive re set?? How do I do that?
@Daisy58
See the link provided above in the post marked as the answer.
I have not completed a hard drive re set ? How do I do that? It says technical fault ? Only terrestrial channels are working no sky??
@Daisy58
So is the error message problem with the hard drive or technical fault?
If it's technical fault try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Try the troubleshooting on this link.
