Discussion topic: My SkyQ Box keeps showing the Programme Info Page of the last recorded show.
This message was authored by SteveLeg This message was authored by: SteveLeg
So I am watching the Show and it ends. Suddenly the Info Page for that recorded show appears without prompting. It stays like that all night. Happens on all Sky TV channnels
Re: My SkyQ Box keeps showing the Programme Info Page of the last recorded show.
Hi @SteveLeg
