Discussion topic: My Sky box only turns on if I disconnect and reconnect the HDMI lead
This message was authored by: debbielou
So from Saturday, and without warning, my sky box will only turn on if I disconnect and reconnect the HDMI Lead.  Its a new Sky Q box (only a month old), and the HDMI lead is less than 12 months old.
Re: My Sky box only turns on if I disconnect and reconnect the HDMI lead
Hi @debbielou
Assume this is from Standby and you are not turning on at 6he mains.
