Discussion topic: My Sky QBox has stopped connecting to my wifi.
Message posted on 10 Jan 2025 11:32 AM
Evrything I have tried does not seem to reconnect my wifi.
Message posted on 10 Jan 2025 01:31 PM
							Re: My Sky QBox has stopped connecting to my wifi.
Hi @Action4
Have you exactly completed the following?
Message posted on 10 Jan 2025 02:33 PM
Hi.
Yes I have tried everything you say but still no luck with connection.
Regards.
Message posted on 10 Jan 2025 04:11 PM
@Action4 wrote:
Hi.
Regards.
Hi @Action4
I have escalated your post to Sky.
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
The link below explains how the escalation process works
Message posted on 10 Jan 2025 06:18 PM
Hi Oldfella
Thank you.
Message posted on 11 Jan 2025 01:28 PM
Thanks for escalating this. We’ve sent @Action4 an invite to chat.
Message posted on 15 Jan 2025 10:53 AM
Thank you for the help with this matter. I have a engineer appointment to try to solve this issue.
Message posted on 15 Jan 2025 12:34 PM
Let us know if/how they manage to resolve
it is a common issue and all intel is appreciated.
Message posted on 21 Jan 2025 09:47 AM
Update on my Qbox internet connection.
A sky engineer called this morning. After telling him I followed the advice from this forum to press the WPS button on my router and not my Qbox which did not cure the issue. It was a simple fix of just press the WPS button on the Qbox and the router.
Happy to say all sorted now.
