2
This discussion topic has been answered Discussion topic: My Sky Q mini box isn’t working. It won’t let me enter the WiFi code
This message was authored by: JAK61
My mini SkyQ mini box isn't working. I can't link it to the network. When I try to reset the WiFi connection it either goes to Step 4 of 4 or won't letter me enter my WiFi password.
Re: My Sky Q mini box isn’t working. It won’t let me enter the WiFi code
Hi @JAK61
Unless you are on Sky Broadband the mini must connect to the main Q box if using WiFi.
Reboot the mini as above.
Hi @JAK61
Avatar for JAK61
Thanks, very helpful
