4
This discussion topic has been answered Discussion topic: My Sky Q main box is not working. I have tried turning off from the main electrical switch twice but
This message was authored by: Luxylux345
My Sky Q box is not working. I have disconnected from the main electric socket twice, however it is still not working?
Re: My Sky Q main box is not working. I have tried turning off from the main electrical switch twice
Hi @Luxylux345
If the Standby button (on the front right of the box) is Amber try pressing that.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
@Luxylux345
Any on-screen message?
Hi @Luxylux345
Avatar for Luxylux345
Thank you Oldfella,
Sky Q now working.
This message was authored by: Tony+Ballam
Thanks. Fixed my problem
