Discussion topic: My Sky Q box keeps shutting down.
Message posted on 06 May 2024 10:01 PM
My Sky Q box keeps shutting down every 30 minutes. Once it closes down it restarts itself and runs for a further 30/40 minutes and then does it again.
Message posted on 06 May 2024 10:08 PM
Re: My Sky Q box keeps shutting down.
Is the Q box well ventilated and Not stacked with other devices.?
Also does it feel very warm?
If it seems normal temperature try a Reset Settings in the Q box hidden menu. See if that helps.
