Discussion topic: My Sky Q box is working as normal, but my mini box keeps switching itself off and on again
This message was authored by: nodsie64
I need to speak to someone, but Sky doesn't seem to offer any actual tech support anymore
Re: My Sky Q box is working as normal, but my mini box keeps switching itself off and on again
Hi @nodsie64
Try a Reset Settings in the mini box hidden menu.
Carry out the first Reset (Reset Settings)
After the Reset you will have to re pair your mini Bluetooth remote If you use one.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini box.
Make sure that you are pointing the remote at the mini box when you press 1 & 3 together.
