Discussion topic: My Sky Q box is not loading the TV schdules list (loading for about 5 hours)
Message posted on 11 Jun 2024 07:39 PM
on the channels section i have been getting message for over 5 hours saying waiting for TV scehdules
this is on the sky q box and also the box i have in bedroom
additional the remote wont let me pause live tv
all other areas seem to be working ok
i have updated the software and have rebooted a couple of times
Message posted on 11 Jun 2024 08:18 PM
Re: My Sky Q box is not loading the TV schdules list (loading for about 5 hours)
Hi @ChrisH4
Try a Reset Settings in the main Q box hidden menu.
Message posted on 11 Jun 2024 09:55 PM
hey buddy many thanks for the tip and response i will give it a go as suggested
many thanks
Regards
Chris
