Discussion topic: My Sky Q box is connected to the internet but it’s not letting us connect to apps or cinema.
Message posted on 02 Dec 2024 05:48 PM
Please help us get our apps reconnected.
Message posted on 02 Dec 2024 05:51 PM
Re: My Sky Q box is connected to the internet but it’s not letting us connect to apps or cinema.
We have followed the process on screen, pressing the WPS button and it doesn't work.
Message posted on 02 Dec 2024 07:28 PM
Hi @DebsL72
Have you exactly followed the procedure below.
