Discussion topic: My Sky Q box has sound but no picture
Message posted on 23 May 2023 09:42 PM
My SkyQ box has suddenly lost picture but the sound is still on. Have reboot box and changed HDMI port. It comes on for 1 minute then goes black but sound remains
Message posted on 23 May 2023 09:48 PM
Re: My Sky Q box has sound but no picture
Hi @Julie+DD
Message posted on 23 May 2023 10:53 PM
Thanks for the tip but that didn't change anything. The screen goes black after exactly 60 seconds. Only way to bring it back is to click Source button on TV control
