20 Apr 2024 06:35 PM
I have a problem with my q box. The red light stays on but the remote does not work and I cannot get to any screen. The TV switches on but on to free view. Then nothing works. I've rebooted both the internet and the sky q box. Help
20 Apr 2024 07:05 PM
Hi @Chutton
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
