Discussion topic: My Sky Q Mini has stopped working. Reset it and when it tells you to press the Home button after
This message was authored by: Lead+Head
After the screen goes blank nothing happens and will not turn on, however if you manually press the standby button on the device it does turn on showing the normal screen, however, it's frozen, no remotes work with it, just stuck.
have reset it several times, reset main box, unpaired both boxes, still get the same issue.
Re: My Sky Q Mini has stopped working. Reset it and when it tells you to press the Home button afte
Hi @Lead+Head
Just try Pressing and holding 7 & 9 together on the remote until it’s led flashes four times. This will reset the remote to infrared mode.
Then make sure that you are pointing your remote at the Q box and see if it will work the Q box without pairing.
If this works try a reset settings on the mini in its hidden menu.
To enter the mini hidden menu press Home and navigate down to Settings but do not select Settings.
Carry out the reset settings
After the Reset you can try to re pair your Bluetooth remote again.
Avatar for Lead+Head
Cheers the 7&9 and 1&3 worked, thanks
