Discussion topic: My Sky Box & TV are on but message on screen says Not Programmed
This message was authored by: Sharky62
Message posted on 05 Aug 2023 06:09 PM
Message on screen says Not Programmed
Find out more
Message posted on 05 Aug 2023 06:12 PM
Re: My Sky Box & TV are on but message on screen says Not Programmed
@Sharky62 It sounds like you TV is on the Freeview input, you'll need to use the remote that came with your TV to select the relevant HDMI input that Sky Q uses.
The message you see isn't from your Sky Q box.
