Discussion topic: My Samsung messge TV will switch of in 60 seconds, how do i clear using my remote sky q
Message posted on 09 Apr 2023 04:18 PM
I get the message I think when I haven.t changed channels for a while so I just let it switvch off and then I switch on again but I am new to sky q and my last remote i simply pressed the appropriate button to prevent the switch off but I cant find a way with my new sky q remote
Message posted on 09 Apr 2023 04:43 PM
Re: My Samsung messge TV will switch of in 60 seconds, how do i clear using my remote sky q
Hi @Gerry+GG If it is a TV message then volume up & down.
Message posted on 09 Apr 2023 09:45 PM
Sounds like an eco setting on the Samsung TV, I get the same after 4 hours if I've not touched the remote - usually on the long F1 shows and the like. You can turn these controls off within the TV settings menu.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
Message posted on 09 Apr 2023 09:47 PM - last edited: 09 Apr 2023 09:49 PM
That 's what I use on my TV
As the others say when watching via SKY it can be easy to not 'interact' with the TV which makes it think it is not being watched - a simple 'dab' on the volume will keep it alive
